-   -   Let's See How You Get Your Cub Snow Ready? (https://www.onlycubcadets.net/forum/showthread.php?t=7178)
dieselsnowmobile 12-29-2011 06:29 PM
3 Attachment(s)
Got my cub ready. Besides the washer fluid filled tires, the 60 lb concrete wheel weights, the 200 lbs rare weight, and the extra 42 inch blade extension wings, I added 4 million candle light power (2 million each) power by a spare battery this year. Seems like I add something more every year. Should be enough light if we ever get any snow. The lights are just zip tied on a tube steel mounted across the back, so it I ever wanted to use the lights separately, I can just cut the ties. Whole light setup cost only $4 in parts I did not already have.
darkminion_17 12-29-2011 07:24 PM
Wow,looky that!!
Good use of concrete for weight.How much effort is there to lift that blade?
bogey68 12-29-2011 08:43 PM
my 129 ready for the winter
Nice ebay find huh ???
Cubcrazy 12-29-2011 09:35 PM
Originally Posted by darkminion_17 (Post 108003)
Wow,looky that!!
Hopefully you have a spring assist!:biggrin2:
Nice blade though!
Cubcrazy 12-29-2011 09:36 PM
Nice find on the cab!:beerchug:
ACecil 12-29-2011 11:15 PM
Nice cubs, guys! :beerchug:
dieselsnowmobile 12-30-2011 08:07 AM
Wow,looky that!!
Thanks, it is all arm power assist. Gives my arm a good work out as it is pretty heavy. When I take the extensions off, it feels so light.
MOturkE 12-30-2011 10:24 AM
Do these things draw heat inside from the motor? As a windbreak it would be great but with heat, snow removal would be enjoyable.
Cubcrazy 01-01-2012 08:25 PM
2 Attachment(s)
Finally got the wheel weights installed on the 2072 so it is ready for snow duty. Chains on the tires and the tires are loaded. The 54" power angle Haban is ready!
Cub Cadet 123 01-01-2012 08:36 PM
Mine holds the heat in if the sun is shining (longwave radiation) and a little in from the engine. You definitely do not want an airtight cab or you'll be napping in a way that you don't want to me napping! None of mine are airtight, but they are comfortable enough to make snow removal even more enjoyable. My only complaint is that it is difficult to see close to your sides if you have a little dog wanting to be at your side or something like that....
Great pics fellas......keep 'em coming!
