Aagitch Did you say something about lifting high?
http://i172.photobucket.com/albums/w...20020Small.jpg http://i172.photobucket.com/albums/w...10015Small.jpg Someone on here had asked me for pics of the plow a while ago. Here is the only thing I have handy. http://i172.photobucket.com/albums/w...20013Small.jpg I've got my plow painted but haven't got the frame done yet. I used rustolieum rusty metal primer on the whole blade. I used rustoliem flat black on the back of the blade 2 coats. and ez-slide graphite paint on the face. It seems to work better on the blade than the blower. My edge is pretty worn as well. For the time being I flipped it. Extreme motor works sells new edges for these in Stainless steel. Hopefully before next winter I'll have one. |
I think my setup may be a bit different, here's a pic showing it. This is actually from the parts diagram for a 451 snowblower, for some reason they don't show the crank arm on the plow diagram.
Mine is home made, but same idea. A slot in the crank fits over the flat's of the end of the rock shaft (maybe I'm calling the wrong thing the rock shaft?). Two cap screws bolt through the shaft end. This shaft end sticks out of the frame by the turning brakes. https://lh4.googleusercontent.com/_h...Handle.gif.jpg |
Squatch,
Real nice photos, thanks. That's what this forum is all about for me. I have 2 1872s and on one I damaged the rockshaft trying to lift my snowblower. I was looking at it the other day and I can't figure out how to remove the rockshaft without taking almost everything out and pretty much taking the frame apart. Is there an easier way? Thanks |
Thanks squatch,
I found a haban blade last year and had no idea what that strap was for, so of course I didn't put it on and I broke the implement end off my rockshaft just like your pic. I had the end welded back on because I could not get the bell end driven thru the rockshaft no matter how hard i beat on it, the pins came out ok but that thing wasn't budgin'. anyway I had it welded back on the end and now the holes on the support strap are about a half inch off ! I will just drill another hole and hopefully that will work. Wish I had used that strap in the first place! arghh! |
1872 from last winters biggest snow.
look familiar? |
http://www.onlycubcadets.net/forum/s...ead.php?t=2912 Hate to tell you this but that is one of the worst jobs you will encounter with these tractors. Getting out a broken rock shaft. Probably the easiest way is to take a sawall and cut out the center section and install another unit. Make sure you already have the other unit that has been seperated into 2 pieces before you start cutting. I would try to get a used one from one of our sponsers here. In my case I was surprised to find That mine came apart easy. I had put such an impact on the shaft from running my plow into an immovable object at speed that it broke the rust loose between the inner shaf and outer tube. I posted one link above but feel free to go to my profile and look up my old threads. There are a couple that address this broken shaft. I used it as an excuse to take the tractor apart and resto it myself. |
CC parts site
I have been using the cc parts site for over two months pretty frequently and just last week they had a big redo on the entire "Older" model tractors. I actually ordered several parts that they showed available and then was notified that they were NLA. That must have happend quite a few times for them to realise that the site was no longer current and they redid it. Our sponsors above have a lot of good stuff a very reasonable prices so we are not totally lost.
| All times are GMT -4. The time now is 04:25 AM. |
