-   -   Trouble with PTO clutch staying on when in run position (https://www.onlycubcadets.net/forum/showthread.php?t=61086)
dachtera 05-23-2023 08:39 PM
Originally Posted by beancent (Post 525674)
I would guess that your relay looks like a typical relay, black plastic outside about 1 1/4 square inches with 5 or 6 spade terminals on the bottom to connect your wires to. Do you have a ohm meter to do your testing with? Not really sure where they placed the pto relay on your 1872.
This is what I have on my cubby. Old school, nothing plastic
https://www.ihccw.com/image/cache/ca..._1-450x450.JPG
No safety's, nothing. all bypassed heh.
1711Cub 05-24-2023 07:33 AM
Those good metal cased HD relays were sourced from Delco Remy, and were used on GM vehicles for A/C high speed blower motor fan relays and headlight door relays on hideaway headlight cars.
They don't fail often. Typically, either the seat switch or reverse switch/circuits are to blame for the issue you are experiencing.
dachtera 05-24-2023 10:47 AM
I do not have any of the safety items, they were all removed prior to us owning it. "ran when parked' best fits my case HAH.
beancent 05-25-2023 06:11 PM
Were you able to do any testing at that pto relay to make sure you have the 12 volts at both the brown and white wires?
dachtera 06-21-2023 08:10 PM
I have +12 on the white, nothing on the brown.
