-   -   Bought a 1450 (https://www.onlycubcadets.net/forum/showthread.php?t=55346)
sorner 07-03-2019 10:30 PM
2 Attachment(s)
Originally Posted by ihcubcadet147 (Post 484545)
i may be interested...
Sorry it took a while. PM if interested.
Attachment 100615
Attachment 100616
ACecil 07-04-2019 04:51 PM
Nice find on the 1450!
IHCubCadet147 07-04-2019 10:23 PM
Attachment 100615
Attachment 100616
PM sent
Thanks!
IHCubCadet147 07-06-2019 08:27 PM
2 Attachment(s)
I pulled the motor today. The two right side mounting bolts were missing, which was probably causing most of the shaking.
I have more pressure washing to do, check the driveshaft, the cradle upgrade, and change the hydro fluid and filter.
sorner 07-10-2019 11:23 PM
Missing bolts with get it shakin' and bakin'. Hopefully all four mounting bolts and those parts I sent you will help you out a lot.
:beerchug: (that's root beer)
IHCubCadet147 07-11-2019 09:38 PM
They should help, we will see next week when I put it back together.
IHCubCadet147 07-16-2019 10:22 PM
2 Attachment(s)
I got the cradle welded today, now I can start putting it back together. The motor mounts were definitely in need of replacement.
sorner 07-16-2019 10:23 PM
Wow. They’re shot.
ol'George 07-17-2019 08:10 AM
Yep,
sum'en plum used all the good out of them rubber baby buggy bumpers fer sho' :biggrin2:
FYI.
Hope you firmly bolted the rails to the block before you welded the cross brace.
Most times they still "pull/draw so some tweeking is required.:bigthink:
IHCubCadet147 07-17-2019 10:24 PM
Originally Posted by ol'George (Post 485288)
Yep,
FYI.
I bolted an oil pan on to get the spacing right, clamped the cross brace on, then removed the pan and welded it. We’ll see tomorrow if it fits.
