everything is good at the carb. i'm thinking electric because i just stuck a brand new battery i just bought on it and tried to start it and it does the same thing
coil or push button is not going to cause it to turn over hard, if it turn over as hard as you say it does. then you are looking for something that rotates
How many times do we have to say this is a mechanical problem before you stop listing electrical parts?
It's a mechanical problem. |
so your saying its probably something in the motor. i'm just out of ideas at this point it acts like a dead battery kinda but even with the charger on it i still got nothing
if i pull the spark plug out the engine will spin put the plug back in and nothing
Pull the head and make sure the ACR is working.
Will mine have an acr since it's a first year original
not if its still the original engine. then it would have a spark advance , most know it as a 2 piece cam
So to check all that I guess i'll have to take the engine apart
| All times are GMT -4. The time now is 10:12 PM. |
