-   Tractor pullers using Cub Cadets! (https://www.onlycubcadets.net/forum/forumdisplay.php?f=12)
-   -   Wheel Spacers (https://www.onlycubcadets.net/forum/showthread.php?t=26918)
Tim.E 08-27-2013 08:46 PM
Those rims probably won't work with the 122 fenders either,because your rims have more backspacing than stock Cub Cadet rims.The 122 fenders measure 15-3/8 between the fenders if you use the original seat tower/mount ( the part that the fenders bolt to).In the pictures,it looks like you probably don't have that much. You may have to get some Cub Cadet 8.5 x 12 rims in order to use stock Cub Cadet fenders.
I don't think 26" tall tires will fit under the 122 fenders without raising them up an inch or two.
Nightow1 08-28-2013 12:36 AM
Ok I think I got it. I'm going to cud 4.25" from the center of the 126 fenders, then weld them back. That will make it 10 1/8 " and fit the model 70 frame perfect. Then Ill just reenforce with 1/8" flat steel for the mounting holes. This should make it fit both height and easily take 26" tires. Or SO I HOPE LoL.
Well I say Me but what I relay mean is My friend Trent, He is a master fabricator, so if anyone can make this work he can.
Wish me luck. I will post some pix as we go.:beatdeadhorse:
SwampRatt-1977 09-25-2013 11:28 PM
Those are 1x6/7 fenders bud :beerchug:
Nightow1 09-25-2013 11:35 PM
All fixed....:beer2:
ACecil 09-26-2013 11:18 AM
Looking good!
austin8214 09-26-2013 02:07 PM
Your going to wish your tires are in tighter to your frame.
Nightow1 09-26-2013 02:53 PM
they will be with the new rims / tires, just waiting on them
