-   -   Gauges (https://www.onlycubcadets.net/forum/showthread.php?t=26465)
USMC_SGT 08-12-2015 07:20 AM
Just ordered a set of the 1.5" Sunpro guages from summit and a copper line kit for my 2182.
Sam do you have any pictures of how and where you hooked these up? I haven't received the actual kit to see how complete or incomplete it will be for this type of application.
Jon
Sam Mac 08-12-2015 08:42 AM
4 Attachment(s)
Jon
These pics are from a 2182 and a 1641. I screwed up and used the wrong size hole saw and that's why I had to use the mounting panel that comes with the kit that you see in the first pic. You'll have to drill and tap the water manifold for the temp sender. Pull the thermostat out and stuff the area that you'll be drilling into with some wet towels to catch the chips. Oil pressure is easy just a tee fitting. Last pic is the 1641, it only has oil pressure and a voltmeter but you can see from the back side where the gauges come through the dash tower.
ford4150 08-12-2015 04:37 PM
I used this setup for my Vanguard. Sending unit is just 2 wire hook up; 1 for signal, 1 for ground. 0-80 psi
Matching gauge is a 3 wire hook up; 12V, ground, and signal from transmitter. 2-1/16" mounting hole - same as the hole in a 782 dash.
I prefer the wired unit to the plastic tube. Concerned about leakage/tube rupture.
All VDO components.
http://www.onlycubcadets.net/forum/p...pictureid=6431
http://www.onlycubcadets.net/forum/p...pictureid=6432
http://www.onlycubcadets.net/forum/p...pictureid=6433
USMC_SGT 08-12-2015 05:09 PM
Originally Posted by Sam Mac (Post 341264)
Jon
Sam,
Did that sender for water temp come with the kit? I assumed it did, didnt think to look prior to placing my order.
Sam Mac 08-12-2015 05:36 PM
Originally Posted by USMC_SGT (Post 341311)
Sam,
Yes, it's part of the kit. It's a bulb with a capillary tube connected to the gauge.
USMC_SGT 08-12-2015 05:54 PM
Whew! I assumed....something I need to not do so much these days with how "cheap" most companies have gotten.....
