-   -   1450 and attachments (https://www.onlycubcadets.net/forum/showthread.php?t=22173)
rmunro 01-20-2013 07:34 AM
The engine oil dipstick tube is loose. I tried to check the oil, and the whole thing came up. Is that just a press fit?? Oil pours out now when running.
steve59 01-20-2013 07:52 AM
Yes.....It's a pressed fit. Take it out and clean the area that presses into the block and put some Permatex Form-A-Gasket No. 2 Sealant on it.
rmunro 01-20-2013 08:18 AM
Thanks Steve. Will try and get at that tomorrow.
rmunro 01-23-2013 09:59 AM
Well, only had time for a quick look at the 1450 the other day. Maybe it's supposed to be a press fit, but this one literally will just drop onto the hole. Somebody has bucksheed a bracket that is useless, so this looks to be an old problem. I don't know if it's the wrong tube, or something is missing. Probably won't get back to it for couple weeks.
rmunro 02-01-2013 02:59 PM
Well, got the oil dipstick tube anchored and sealed.
Still have major leak apparently from other side of engine. Hope to get at that this weekend.
Then tackle the hard start issue. Set timing, carb, new fuel filter may be all it takes.
The engine is loose and can be moved around. I think they have bolted cradle solid to frame, at least no sign of ISO mounts.
Bouncing back and forth between it and 1210 I bought same day.
