-   -   How much weight do you add? (https://www.onlycubcadets.net/forum/showthread.php?t=28334)
Redblower 11-19-2013 10:11 PM
So I'm new to this, my next question may be obvious to everyone else but here goes, I am assuming we stay with the recommended tire pressure? Which by the way seems low? I have a 682 with a Haban42 single stage blower (did not come with the tractor so don't have real history with this machine) and I notice when the blower is lifted the front tires are pretty "squashed", not dangerous looking but noticeable.
Thoughts?
Thanks, Vic
J-Mech 11-19-2013 10:32 PM
When running the snowblower, I run my front tire pressure at 30 PSI. :beerchug:
782CC 11-19-2013 11:33 PM
Same here. Lower it for running the blade.
Redblower 11-20-2013 07:16 AM
Wow! Really, good to know, so next newbie question what about the rear tires on this set up, I have 73# wheel weights on each side and that cab I built which I would think goes somewhere around 100#? The recommended 10# (I think) sounds kind of low also?
Thanks,
Vic
riesedesperado6170 11-20-2013 10:57 AM
on my 982 I have loaded tires and wheel weights that add up to 600lbs
J-Mech 11-20-2013 11:38 AM
Thanks,
Vic
I run loaded rears and 75lbs wheel weights. I try to keep the rear pressure as low as I can for traction. Wish they made lug radials for the rear :bigthink: Anyway, I think I run about 15 PSI in them. But I don't remember. I just air them up till they don't squat, and them make them the same. Tried running them squated one year...... not a good idea on bias ply tires. Wore the outside down more than the center. :angry: Honestly I knew better. Nice thing about fluid ballast, is it doesn't actually put weight on the tire. So, you can still run with lower tire pressure, until you add frame/wheel weight.
jimbob200521 11-20-2013 03:34 PM
Well on my 1050 blade machine, I run chained turf tires filled with whatever liquid came in them when I got them plus I'm about to put a set of rear weights on her, too. Oh, and don't forget my 200+ pound fat a$$ :biggrin2:
Being my first year with a blower and limited Cub parts for right now, my 682 with the blower has...me for weight. I don't expect it to have too much traction trouble but worst case I add a set of weights to it.
782CC 11-20-2013 04:24 PM
Where I could move fine with a blade on the front, with a blower it barely could move. So much weight off the rear with the blower mounted. Expect to add something back there. Or always be running in blower cleaned ground. oh and no uphill blowing. At least that was my experience. My 230lb ballast butt just was not enough..
Sam Mac 11-20-2013 05:57 PM
Fill the tires and add as many wheel weights as you can to it. When it comes to weight some is good, more is better and too much is just right.:beerchug:
Redblower 11-20-2013 08:12 PM
Thanks for all of the input, and sorry Bocephus for pinching in on your post. Like I said the blower didn't come with the tractor, came from a guy with a 782D that couldn't hardly get up the small hill in his blacktop drive, maybe 3' in 50'? With the haban single stage blower on the front and weight (just not enough I guess) so he found a 2 stage blower that weighed considerably less that he put on his Diesel. Think someone else mentioned that the weight of the blower is so much that it takes weight of the traction wheels. My drive is flat so I am hoping that I will get by with what I have, if not I have ways of adding it to the rear.
Thanks, Vic
Nightow1 11-21-2013 01:56 PM
Cub 75# weights on each tire outside, IH weights 25# inside each tire, + around 50# of sand/salt in spreader. 250# + my big BU&%, and Chains.
