| twoton |
01-06-2019 06:28 PM |
Originally Posted by Jeff in Pa
(Post 475406)
Since he's getting a new driveshaft from me, if he goes with four flex disc joints, should I move one hole closer ( towards the other hole for the extra disc joint thickness) ?
I guess it would partly depend on existing conditions. The picture below is of my 1975, 1650 when I first got it. I was able to install 2 new rag joints by simple using longer bolts. I did not add a second at the front of the driveshaft as there was only room for one and I didn't want to drill a second hole in the driveshaft.
My 1976, 1200 was a different story. There was only room for one at the back so I filled the original hole with some rod and a tack weld and drilled a new hole farther forward.
My 1979 1450 came with 2 at the back.
So like I said, your existing conditions...:bigthink:
