I gotta ask, did you replace them with this type?
Yes those are the bearings I used. If the 2 cup half’s go together with nothing in between that makes sense. Is that whole assembly dropped in from the top.
Thank you soooo much guys
Well this all makes perfect sense now. So previous owner had top cup installed on top of deck and metal plate and bottom cup on bottom side of deck. I just reinstalled the same way I took apart. I thought this can’t be right 😬. Should work much better now put together the proper way 😂. Thank you all so much for helping so fast. You guys rock👍
