-   What is it worth ? (https://www.onlycubcadets.net/forum/forumdisplay.php?f=61)
-   -   126 with Options (https://www.onlycubcadets.net/forum/showthread.php?t=51855)
darkminion_17 04-19-2018 08:38 PM
Nice quicky paint job, has some extra holes in the hood, check the dash tower where it mounts the clutch arm, they do get cracks, walk away from that unless it is a 599.99 cents.
IHCubCadet147 04-19-2018 08:51 PM
Ok. Thanks for the help. I would have never known to check for this code.
IHCubCadet147 04-19-2018 08:53 PM
Ok, thanks! I will check that if I go look at it.
finsruskw 04-19-2018 09:21 PM
Check the steering for slop. I would not be surprised if it will probably turn 1/8 to 1/4 turn of the wheel before the wheels start to turn.
Check for fore and aft movement of the front axle when you test the steering. Check for looseness of the tie rod and the drag link ends (4 of them).
Check the tightness of the pitman arm alongside the steering box, all while moving the steering wheel some.
Check for loose or sloppy gear shift, make sure the lever does not spin around in the cup.
Check for front wheel bearing slop, (push on the tractor sideways at the front wheels)
For that kind of $$, there should be NOTHING wrong with any of these items, and I should come with a battery, "turn key deal"
Last 126 I bought was $300 and I drove it on the trailer.
IHCubCadet147 04-19-2018 09:39 PM
Ok. I will check these.
