Please Help Me Save My Cub!
Although the engine didn't abruptly stop turning, whenever I hear of an engine that won't start but does have a spark and is getting fuel (and I'm assuming there is compression), I suspect ignition timing. Add checking the flywheel key to the list.
Timing could be a problem, best to go back and double check that. I don't know if the ACR can stick on, usually they just don't work and the engine is hard to crank. HOWEVER, your exhaust valve, which the ACR holds slightly open when starting could be sticking open, thus not much compression, so it could act like not enough fuel. Pulling the head and watching the valve action as you turn the engine by hand is how you would know. |
