-   -   70 clutch rebuild (https://www.onlycubcadets.net/forum/showthread.php?t=40213)
olds45512 08-09-2015 08:30 PM
Originally Posted by Sam Mac (Post 340884)
Red air cleaner cover. :biggrin2:
about half the 7hp cubs i see for sale have a red air cleaner, not sure why.:bigthink:
darkminion_17 08-09-2015 08:38 PM
Originally Posted by mmzullo (Post 340878)
Big battery box?
About the rear cover with cut out. I have a couple of those and always wondered what the cut out was for?
I thought it was for the spring assist,but when you find out let me know.
johns cubs 08-09-2015 09:42 PM
I am getting ready to notch mine out tomorrow, for the lift rod to rear rocker arm for sleeve hitch.
Alvy 08-09-2015 09:46 PM
My guess is big battery box.
So what's the answer Ponch?
darkminion_17 08-09-2015 09:47 PM
Can't tell you...
but you are getting close.
crossingcrown 08-09-2015 09:53 PM
I have seen guys talking about pinching the axle channel.. How well does that tend to hold up for? If you can clamp it shut, wouldn't the pressure of the tire hitting something just bend it back? I have three I was thinking about doing this to. But I didn't want to waist my time if it will not hold up. Just curious.
darkminion_17 08-09-2015 09:57 PM
Originally Posted by crossingcrown (Post 340919)
If you can clamp it shut, wouldn't the pressure of the tire hitting something just bend it back?Just curious.
The whole idea is not to hit the front tire with something or you will bend the axle channel.That is how they get bended
:biggrin2:
crossingcrown 08-09-2015 10:18 PM
:beerchug:
DeltaCub 08-09-2015 10:33 PM
The grill seems to be missing the cast in piece behind the voltage regulator. Casted area around the top panel for headlights is absent.
darkminion_17 08-09-2015 10:48 PM
your getting a little warmer....
