-   -   MMO in the oil? (https://www.onlycubcadets.net/forum/showthread.php?t=34398)
CADplans 09-07-2014 01:37 AM
Originally Posted by Juicybusa (Post 284912)
A couple of thoughts. Gasoline is what has a cooling effect on engines. When the liquid vaporizes it cools. Oil does not have this direct cooling effect. Second, if your adding additional oil to the fuel you are in effect leaning your fuel mixture. Carb jets only flow a finite amount and more oil in the gas means less gas as a percentage is flowing through a fixed jet. Be cautious as we all no what an overly lean two stroke does. If additional oil created a cooling effect, it was because you had inadequate lubrication to begin with and were experiencing increased heat from friction.
Originally Posted by J-Mech (Post 284926)
I'm not really into what you are saying. You make some interesting points...... but I disagree with most of them. :coffee:
I gotta "ditto" J-Mech, most of the negative assumptions requires the additive to change the viscosity of the fuel, with the low % of oil added, that ain't happenin'....
The reduction of burn rate of the fuel by adding oil (kinda like higher octane) has a tremendous cooling effect.
No matter what,,,, (too many variables to discuss),,, the results are better with than without oil, for me,,,, :bigthink:
cubby102 09-07-2014 01:38 AM
Originally Posted by bkw3614 (Post 284929)
I use about 3/4-1 ounce of MMO to one gallon of gas in my 1250 Nightmare. I also use an ounce of StaBil per gallon of gasoline. A good friend, who is a small engine mechanic claims that we need a bit of upper cylinder lubricant to replace the lead that was once in the gas when our Kohlers were built. (sounds good to me) I don't notice any smoke with the MMO in the gas, the engine runs great, the spark plug is very clean and is wearing evenly, and I don't need to drain the gas when the machine is parked in the winter.
I started with 4 ounces per gallon, and that was way too much. the one ounce cleaned up the exhaust and made the engine run better. I am sold on the practice.
It make sense about the upper cylinder lube. But iirc these kohlers were designed for unleaded fuel I believe I remember reading that they advise not to use leaded fuel. I could be wrong but I am pretty sure
athomas 09-07-2014 11:09 AM
MMO
I've been using the mmo for about 5 years 4oz in a 5 gallon can no ill effects at all ,over the winter months a little sta-bil for the 109 & 108 they think it is delicious !!
J-Mech 09-07-2014 11:51 AM
Honestly, I don't know why so many of you guys use sta-bil and MMO, and other additives. I must run my machines more or have better fuel or something..... 87 octane pump gas is all mine ever drink. No problems whatsoever. No wore out motors. No valve problems. No issues sitting. (They seldom sit longer than a month.) No water in my fuel. Nothing. I just don't get why so many on here have so much trouble with fuel. :bigthink:
olds45512 09-07-2014 12:00 PM
I agree, my weed eater sits all winter with gas in the tank and come spring it always starts on the 2nd pull. The 108 doesn't see much action in the winter either unless we have a lot of snow and it always fire right up to.
rwairforce 09-07-2014 12:16 PM
I feel it's not necessarily problems with fuel or anything else, it's more of preventive maintenance. The idea of providing these additives makes us feel like we're doing something that will help prevent issues. Call it good marketing or call it unproven but I think that's the reasoning.
I've always been a little skeptical how a few ounces added to many gallons of gasoline could actually keep the carb clean when I'm not sure it would clean it full strength.. As I said, I've never really tested these products but I can be seen pouring some of it in tanks now and again. I pour some of the cleaning additive in my car too. I don't have any idea if it really helps. I guess the marketing efforts really do work because they have us believing that these product really do help.
J-Mech 09-07-2014 01:22 PM
I'd say you :NailHead:
Just playing "devil's advocate" here.
So..... if at least two of us say no issues with gas (I'm sure there are others), while some say that they treat but have no issues just like the ones who run nothing. Do you wonder if it's a waste of $$?
I work on motors everyday. I can honestly say, I have yet to see a product that "prevents" anything. (Except air line anti-freeze and diesel anti-gels.... they do work... up to a point) There are some good fuel additives that I use on motors that have not been well taken care of. I don't advocate using them all the time to my customers. Once performance improves... the additive stops. If performance doesn't improve then we spend $$ and make it improve. Most of the time we only do this on engines we have opened up and see how dirty the inside, or the fuel/intake system is. FWIW, I have also seen failures on things like engines, transmissions, cooling systems, even A.C. systems that had too much additive in them. Most people don't go to excess, but I've seen it. I for one, think that a continual addition is unnecessary, and can even be detrimental. That's my "professional" opinion. I just wanted to share it. I think they are mostly just taking your money. You all do as you see fit. :beerchug:
PaulS 09-07-2014 01:23 PM
I do use MMO, stabil, and startron in all my small engine gasolines. After talking with several small engine shop owners who all said current gasolines do harm to these engines. I cannot get alcohol free gas anywhere within reason. I have been using MMO for several years now and although only a little per container have not had any fuel related problems with any of the fleet. I am using the stabil because I had a bunch that was several years old and wanted to use it up. The startron I use to counteract the alchohol that is added to current gasolines. Since I have been adding these to my 2 and 4cycle gasses I have seen seen a little improvement in the engines starting up. My gas also seems to last longer without getting the stale skanky smell of old gas.
garnold 09-07-2014 02:16 PM
I do use stabil in my gas but that is because my stuff is not used all that often. I've had to rebuild my carb on my snow blower each year before I started using the stuff. Now I seem to be dodging a bullet because it starts just fine. I even tried to run the blower dry each year but just that little bit left in the carb I guess clogs it up. I'm really not the most handy guy in the garage (but working on this) so if this stuff can even help a little Ill pay the marketing machine :)
gsomersjr 09-07-2014 06:11 PM
Fuel stabilizers do not freshen old gas. It only extends the useful life when added to fresh gas.
