-   -   Driveshaft (https://www.onlycubcadets.net/forum/showthread.php?t=28148)
darkminion_17 10-28-2013 09:21 PM
Alvy,
I am having some made up for me by a friend who is a machinist, he is also truing up a bunch of pressure plates and pto plates.
Gratis is good!
_DX3_ 10-28-2013 09:26 PM
Starting at the transmission end and measuring to center of each hole towards the engine:
1/4" from end
4 31/32" Creeper Hole
8 13/16" Spring Spiral pin hole
15 7/8" Teaser spring hole
17 1/8" End plate
darkminion_17 10-28-2013 09:28 PM
Thank you very much.DX3
_DX3_ 10-28-2013 09:30 PM
Is no problem. Glad to help when I can.
Yosemite Sam 10-29-2013 12:09 AM
First off, understand that I am not disagreeing with or beating up on anyone.
I make my Narrow Frame shafts, 18.1875" (.1875 = 3/16").
From the front,
First hole is, 1.125" (front plate)
Second hole, 2.255 (rear plate)
Third hole 9.250" (tension spring)
Forth Hole, 13.250" (rear coupling creeper)
Fifth Hole 17.9375" (rear coupling no creeper)
I have literally made hundreds of these and have never had a complaint yet.
Good luck with your project.
mickb72 10-29-2013 06:51 AM
shaft
Hi Sam, could you give me those sizes for a wf 128 from the front. Thanks Mike
_DX3_ 10-29-2013 08:49 AM
From the front,
No problem here. I just had a simple tape measure to use. Glad to see the exact specs. :beerchug:
Yosemite Sam 10-29-2013 11:23 AM
Wide Frame models (86, 208, 128):
Shaft length, 19.875" (non creeper) 14.5" (creeper)
From the front,
Second hole, 2.255" (rear plate)
Forth Hole, 14.250" (rear coupling creeper)
Fifth Hole 18.9375" (rear coupling no creeper)
Now if someone would be so kind as to post the measurements of the Quiet Line shaft length and hole locations I would appreciate it very much.
cubby102 10-29-2013 03:30 PM
Sam I can get all the holes down to the creeper tomorrow for ya
darkminion_17 12-05-2013 09:22 AM
From the front,
Seems to be a difference on this chart.
http://s210.photobucket.com/user/DXK...e6df0.jpg.html
