I agree with some of the others that it sounds like a gas problem. Running along fine, then sucks a piece of trash over the tank outflow and cuts off. A little while later it has allowed enough gas to go to the carb and runs fine until the carb runs out of gas. Then the trash moves away from the tank outlet and you are running OK.
Also could be trash in the sediment bowl or in the line or carb needle valve. Let us know what you found. |
Sorry to hear about the Dually.
I would let it cool over nite and try it again. Sometimes coils and condensers will act up again as soon as the engine warms up again. It very well could be a fuel problem, hope you get it figured out. |
Thanks guys, I'll get it figured out.
Keep us posted ACecil.
You know how i get when one of the Cubs aint running right. Keep me up at nite.:bash2: |
Sorry to hear of your Dually troubles Allen:bash2:
Sounds like you have enough suggestions to try out, so I'll just add a good luck finding the trouble:beerchug: |
Thanks Todd! I'm going to give it a good run and see, if it does it again. :beerchug:
I was cleaning up my "subscribed" threads...... did you ever get dually fixed Allen?
Dually has been doing good. I'll find out, once I give him a good run...lol.
| All times are GMT -4. The time now is 08:59 AM. |
