-   -   1572 - a rebirth (https://www.onlycubcadets.net/forum/showthread.php?t=54076)
IHCubCadet147 02-27-2019 07:58 PM
Looks good!
twoton 02-27-2019 08:35 PM
Good to hear you're feeling better. :beerchug:
DieselDoctor 02-28-2019 06:46 PM
Nose is white, decals on, and everything lined up and installed. On to painting the fender pan (again) and this thing is DONE!
DieselDoctor 03-01-2019 07:57 PM
2 Attachment(s)
Naked tin! Got the fender stripped to bare metal today. I used paint stripper, then sanded using a DA with 80 grit, then 220 grit, then a final hand sanding with a maroon 3M Scotchbrite pad. Once the tin was clean, I wiped it down several times with lacquer thinner on a clean cloth. If you use chemical paint stripper on a project, you must be certain to completely clean all the chemical from the metal so the new paint will not be affected.
IHCubCadet147 03-01-2019 08:15 PM
Nice work, that’s going to be like new again!
DieselDoctor 03-02-2019 08:07 PM
3 Attachment(s)
Hooray! The fender pan is yellow and no problems with lifting.
DieselDoctor 03-03-2019 06:58 PM
3 Attachment(s)
Well boys and girls, I put the finishing touches on today. Just waiting on better weather to take it out and run it for final testing, then it's headed back to TN. CubDieselFan is getting anxious!
Thanks to all of you folks for your kind comments. It's been a fun project.
Sam Mac 03-03-2019 07:18 PM
Looks good as old and better than new. :beerchug:
darkminion_17 03-03-2019 07:20 PM
Looks like new! delivery will have to be on a nice day, or it will get very dirty....
CubDieselFan 03-03-2019 09:27 PM
It looks awesome. Thank you Stan for a job very well done.
