My Cub is done for the season but I have noticed a recent problem, when cutting for around 30 minutes the motor sputters for a sec and then just cuts off you can hear the piston move up and down and then a slight backfire. When I let it rest it runs just fine for another 30 mins. Does it have a temp sensor or could it be overheating? The fan on the drveshaft is on and I have the side pannels on, or is it time to retire it?
Check the coil. It's getting hot and losing spark.
My 1250 did that.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 1985 1711, 44C deck, Rear 42" Brinly blade Southern Kentucky Cub Cadets https://www.facebook.com/SouthernKentuckyCubCadetClub |
i dont think a cub would know how to retire haha
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
Nick is right. Cubs are like the Six Million Dollar Man. "We have the parts, we have the knowledge, we can rebuild it." :biggrin2.gif:
and/or possibly water in the gas. it is very easy to do, and will cause it to act that way. |
Thanks guys for all your advice! I will check the gas flow and is it easy to replace the coil? Or should I have a mechanic do it? OOhhhh also is it expensive?
An OEM Kohler Coil runs around 45 bucks. I hear NAPA has an after market coil for around 20. Just pop the right side panel off and there it is. Very easy to change.
You might check the point setting also, before you spring for a coil.
do the easy/no cost things first, LUCK! |
Exhuast valve is sticking when the engine gets hot. Pull the head and exhaust valve, clean the stem with a brass brush mounted in a drill or drill press. You also HAVE to buy a valve guide reamer and clean the carbon in the guide. I found mine on Ebay! My 1450 and 1650 did the exact same thing. this fixed both!
I had a similar problem with my 1650. Turned out to be that the float wasn't dropping enough and when the engine burned about 1/2 tank of gas, it would quit. I let it cool a while and it would run again. Replaced the coil... same thing.
![]() I checked the fuel valve for rust/crud, clean as a whistle!! ![]() I finally removed the carb to check for a blocked passage somewhere and I noticed (carb was still hot) that the float wasn't dropping down far enough. So when the carb got hot, the float needle magically closed SHUT!!! ![]() Some OLD WISE man once that "Ve get too soon old and too late schmart". I bent the tang away from the seat a little more and the problem disappeared. Perhaps someone else can learn from this experience... ![]() FFGino. Happy Cubbing!! |
| Thread Tools | |
| Display Modes | |
This website and forum are not affiliated with or sponsored by MTD Products Inc, which owns the CUB CADET trademarks. It is not an official MTD Products Inc, website, and MTD Products Inc, is not responsible for any of its content. The official MTD Products Inc, website can be found at: http://www.mtdproducts.com. The information and opinions expressed on this website are the responsibility of the website's owner and/or it's members, & do not represent the opinions of MTD Products Inc. IH®, INTERNATIONAL HARVESTER® are registered trademark of CNH America LLC
