421U111 deck on a 129?
I managed to pick up a nice deck today off a 104 cub today.The guy was stripping all the stuff off the tractor to make a puller.I got the deck and the mule drive for 20 bucks plus the belts.Does any one know if I can make this work on my 129. I know the mule drive wont fit but wondering if my mule drive on my 129 will.Looking at the difference couldnt see a lot other than width of the mule drives and the angle on the one pulley.My 44c deck that came with the 129 needs a lot of attention.If this would work it will give me time to rework the 44c like it needs.Any and all replys welcome....Thanks in advance Randy
I think the deck will work on your 129...it does not hurt to try! It will take a different PTO belt I think...but before I'd buy a belt, I stick the 42 under the 129 and do a mock fit.
Co-Founder You only need two things in life...duct tape and WD-40 If it's stuck and needs loosening, use the WD-40. If it's loose and it's suppose to be stuck, use the duct tape. |
I am not sure what the difference is , Mine is a 422U1111 and it is under the 149. If it looks something like this it ought to work.
Thanks guys the mock up is gona happen today.Diz it looks just like that so thats good news...I get a little confuzzed on which decks fit what sometimes...
Diz do you remember what pto belt you used?
Here is a belt chart...find your 129 then the deck and it will give you the belt size...
http://home.comcast.net/~dos0711/CCBELTCHART.htm
I have an extra 42" IH-490489-R2-3/8 X 80" belt.
Pat Benner Haskell OK Keep the Deck down and the Throttle open!!! |
Thanks guys for the info I new I'ld seen that chart somewhere before big help....Thanks for the offer on the belt but it looks like I need the 3/8 by 81 inch belt for this...Good news after work today I got it all installed on the tractor with out much of hitch.Bad news no belt I have or could find local would fit.Does anyone know a good place to look for the 3/8 belts?When you need a belt you need a belt.Ive been to tractor supply,Orielys and one local lawnmower shop but nothing so far....Im going to try napa tomorrow.My local Cub dealer is absolute of no use for anything.Been there 3 times for other parts and will not be back...Long story there.
My NAPA was able to order a belt that was close to what I needed, but it was an automotive belt. It will work as a spare. I needed a 75 1/2 and they had a 75.
I don't know what size mine is but the number on the belt is 490489R2.
Its a Cub Cadet belt. I am lucky enough to have a great dealer close by. |
