Cub Cadet Classics R. F. Houtz and Sons
Patton Acres Binder Books
CC Speciaalties IH Cub Cadet Parts
Only Cub Cadets Chat!
OCC Archives
Old 02-23-2015, 08:28 PM
Ikea6e Ikea6e is offline
Default 1811 Foot Control
This style uses a 1981 Tempo transmission shift cable and a homemade return to neutral (RTN) device.
These are the major parts for the Pedal and RTN device.
Foot pedal parts.
Foot pedal parts assembled, ready to bolt on to the right foot rest.
RTN prototype.
RTN prototype assembled.
RTN levers cut out of flat stock and on the mounting bar.
Complete RTN device.
Tempo (or other approx. 42 inches long) shift cable mounted to the left side of the tower and attached to a bracket coming off the Hydro Control cross shaft.
RTN mounted under the right foot rest. RTN and shift cable are attached to the bottom of the foot control assembly.
The adjustable rod from the RTN to foot control allows easy adjustment of the RTN neutral and the tractors neutral with brake pedal depressed. (Make sure the hydro does not creep prior to starting this project) The hardware sourced springs pull the hydro to neutral when you take your foot off the pedal (or spots in between). The springs need to be strong enough to do so. The pull on the RTN can be adjusted to your preference by the ¼ -20 adjusters and spring strength.
Back off the friction lock, as it is not needed and makes it easier for the RTN to do its job. A Damper was not needed. I suspect the shift cable served that purpose. I used a new shift cable $30 or so from e-bay. But that was a few years ago. After trooping around a number of junk yards and going thru the effort of removing what turned out to be a junk cable, it was worth the $$.
I no longer have this tractor but this setup worked well for a number of years. I used this one mostly for blowing snow. If I use one like this again (RTN under the foot rest) for snow duty I would figure out a way to keep the slush and salt etc. off of it.
Old 02-24-2015, 01:16 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Default Thanks!!
Nice work!
Thanks for posting these, Ike. I am going to give this a try after I get some other projects out of the way. Nice write-up!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072 w/23HP Vanguard AKA THE 2372
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-24-2015, 02:27 PM
Well done.
1864 next into rehab
1641 AKA Black Jack #2 with 46" deck (on loan to the Step Son)
149 with a 1A Tiller
JD330 with 50" deck and 3 point hitch.
BX2660 with FEL & Grassanator
Old 02-24-2015, 02:49 PM
jimbob200521's Avatar
So where do we sign up for the kit?
Job well done
-Ryan
Old 02-24-2015, 03:42 PM
Nice work!
Thanks guys,
Check with Travis, since he is going to make one, perhaps he will do 2 or 10 or ???
Ike
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
This website and forum are not affiliated with or sponsored by MTD Products Inc, which owns the CUB CADET trademarks. It is not an official MTD Products Inc, website, and MTD Products Inc, is not responsible for any of its content. The official MTD Products Inc, website can be found at: http://www.mtdproducts.com. The information and opinions expressed on this website are the responsibility of the website's owner and/or it's members, & do not represent the opinions of MTD Products Inc. IH®, INTERNATIONAL HARVESTER® are registered trademark of CNH America LLC
