Greg Rozar AKA- CubDieselFan
Old 02-09-2018, 06:29 PM
smokeman smokeman is offline
Set the SP mark in the window, then using the test light, adjust the points to just break contact and light the light. You have to adjust them. Forget the feeler gauge.
If you don't understand the article I linked to, then I can't help you. I laid it all out in as simple terms as possible in the article.
Ill keep fooling with it. Ill get it figured out. Thanks for your help.
Old 02-09-2018, 06:37 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Don't you suppose you have other issues to address besides correct timing in order to get your engine to fire?
Fuel?
Compression?
Spark?
Something else?
Plow blade
#2 Cart
QA36 snowthower
Old 02-09-2018, 07:01 PM
Smokey, dumb question, are you rotating the engine the correct way while trying to accomplish this?
Old 02-09-2018, 07:03 PM
Hi Bill, I can get it to run with the feelers at .020 which gets me close, just wanted to get it right on with the J-Mech method. Ill work with it tomorrow and see if I can get it figured out. Smoke
Old 02-09-2018, 07:06 PM
Hi Alvy, not a dumb question at all, actually I never took thought of the direction. I can say that I was turning the belt pulley on the generator clockwise to get the SP in the port hole.
Old 02-09-2018, 07:07 PM
If you’re viewing that from the front of the tractor that is the wrong direction. Do it the other way and you will have success
Old 02-09-2018, 07:12 PM
Ha Ha, thanks Alvy. I am left handed, thats probably what happened. Never could get a pair of right hand scissors to work either.
Old 02-09-2018, 07:31 PM
Poser Poser is offline
Just hanging on here, that was a good writeup on timing Jmech, thanks, I'll try it soon.
OP, good luck with your timing.
Kevin
But us lefties think with the RIGHT side of our brains
Old 02-09-2018, 07:49 PM
Thats RIGHT George.
