Homemade solid hitch for CC 106
Attempting to make a strong hitch for moving boat around yard, ready to roll weight is 3500 lbs.
Welding done by a true welder, not me. |
I think you should build a tandem cub like sawdustdad did but instead of a dump bed you should put a fifth wheel on it.
You're planning on moving a 3500# boat using the back of a 700# garden tractor.
Ok...... That doesn't sound like a bad idea. I use my truck to move my trailers around. Or my Lo-Boy. But it has 3ph and is just a tad larger than a GT. Even it has it's limit..... |
I know, but It's IH, I trust it, my yard is flat. Maneuverability is what I'm looking for, It's a Cub, stopping shouldn't be a problem.
Low gear, just off idle. Other than that, It's a toy and sounds old school, I like that sound. I have much practice pulling things, I will update. Thanks. Kevin |
I just don't understand why anyone want to use them to move a trailer. I've never had an issue using a truck. I can put a trailer anywhere with a truck. If the area isn't large enough for a truck to get the trailer into, then the trailer doesn't need to go there. But that's my opinion I suppose.
Carry on. But if you sheer the bolts off the rear, or tear something up, don't say you had no idea.... |
I move my tri hull 21' fiberglass deckboat around when ever I need to with my 127. Have not weighed it but it is close to this 3500lbs. Granted I am on level ground and it is 12hp hydro. A 106 might just burn the clutch before something breaks though. |
When hitch is complete, I'll show serious attention to detail, It's severely overbuilt!
Anything I can make strong can be made even stronger, you guys will approve, appreciate all comments. Thanks. Kevin |
I am not picturing where the piece pictured above is going to end up. |
The 3/8" bolts that hold the hitch to the rear....
Me either. |
I don't think he is utilizing the original CC trailer hitch. Nor the entire rear end cover plate like this custom hitch:
Maybe like that but higher. Since he is shooting for a hitch point 18" high. On mine I used one of these brackets and then welded a 2"sq receiver tube on under the hole in the center. Puts the receiver up close to 18" or truck level. |
Thread Tools | |
Display Modes | |
