#21
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#22
Doc trust em, it is there, I had the same problem with my 100. After cleaning it and using a light shining at an angle I found it.
Larry |
#23
Absolutely. The knowledge on here is unbelievable. I'll get the tractor in the shop tomorrow, heat on, good light and a wire wheel on the grinder and we'll find it!
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
#24
Bad part is... the serial number won't tell you if it was built as a 70 or 100.. It will only tell you what year and month it was built... I don't think IH kept records of which model it was since they were building both at the same time.. I've always heard that all the 70's had bushings in the rear axle tubes and the later 100's went to bearings.. It could be a 70 with a 10hp or it could be a 100.. does anyone know how to tell for sure? Good thing is you can make it whatever model you want it to be!
#25
Here is where one of my 100's is stamped Doc. It's gonna be freezing here today too with a high of only 54* and sunny.
#26
Don B, USAF 1962-1968, Ft. Wayne, IN |
#27
Found the serial number!! 87618 making it June/July of 1964. It was on the GRH casting, adjacent to the little square, but not on it, and was below the rectangle under the frame rail. It is stamped uniformly and in the size of the numbers on the Original, so I'm happy. Thanks to all who helped get me on target. I also cleaned the tag on the Kohler --- K241 serial D128880 So if the serial matches the time frame of the tractor serial, it looks Like I have a 100. Can anyone point me towards Kohler serial numbers vs year, if such a thing exists?
#28
http://www.onlycubcadets.net/forum/s...ead.php?t=4646 |
#29
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
#30
I always thought the 100's had,
The wide spoke steering wheel. Shorter choke and throttle cables. Bigger battery box. 100 on the hood. If it was a 70 with a 10 horse you should see the remnants of the oil pan outline on the frame and versa visa.
Thread Tools | |
Display Modes | |
