Greg Rozar AKA- CubDieselFan
Old 05-26-2017, 11:15 PM
Shotgun Clay Shotgun Clay is offline
Default Homemade(ish) rear blade.
With my homemade rear lift, I wanted a rear blade to go with it. So I made one. The actual plow is a montgomery no trip blade. I used some square tubing and some rectangular tubing welded together as a mount. After using it today i was VERY happy how it worked. You can see how I used it to "back drag" gravel out.
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 05-27-2017, 07:03 AM
john hall's Avatar
Looks like it is doing well touching up the driveway!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-28-2017, 12:14 AM
Hey, if it works for what you built it for, it's all good.
It's good to be able to make something useful out of something you have laying around.
Old 05-30-2017, 11:45 PM
Default Update
When I have nothing to do, I go to the shop and do something. And that happened today. I decided to put some 1/4 in flat bar as a wear/blade edge on it. I also moved the lift linkage to an easier spot, making it so I can angle the plow. Too bad it is the beginning of a hot and humid summer, I want some snow pushin seat time!
Clay
