Greg Rozar AKA- CubDieselFan
Old 08-31-2011, 12:20 PM
Thanks for the update!
Proud owner of my Original!
Old 09-29-2011, 01:47 PM
149 - 498944's Avatar
149 - 498944 149 - 498944 is offline
Default Priming Beginnings
With the 149 totally disassembled, sand blasting done, battery box fixed and some general body work completed it was time to start painting.
A friend of mine and I decided to do our 149's together. Here is a pic of primer going on.
Cub Cadet 149 (Restoration Completed 2012)
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 09-29-2011, 01:56 PM
Looking good! Thanks for the update.
Old 09-29-2011, 10:23 PM
Sugarmaker's Avatar
Very nice! thanks for the update on the status of your restorations.
Man It would be nice to have a sand blaster! Is it big enough to get a frame in? The hoods and frames look great in primer Too.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-24-2011, 10:50 PM
Default Sandblasting
Blasting was necessary on 149 - 498944. Someone had sprayed on several coats of red oxide primer and then brushed her down with some kind of rust inhibitor that turned to a rubbery substance. The tins looked a mess when I first rescued her.
I did the blasting outside in a make-shift booth to contain the media for recapture. Here is a pic
I hooked 2 air compressors together in series to supply the air pressure to a modified blasting tank. Ran at about 90 psi. Blasting the frame took about 20 minutes. The mod to the tank consisted of drilling out the bottom fitting and re-tapping. The original orfice is so small and restricted it is prone to clogging.
Blasting provides a great surface for priming but remember, it takes more primer. The surface area is actually increased when blasted.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 10-24-2011, 10:59 PM
Default Restoration Progress
Fenders painted. Took 4 coats of the NAPA yellow.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 10-24-2011, 11:03 PM
Default Frames Painted
I know the pictures make the fenders and frames look different but the color does match.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 10-24-2011, 11:12 PM
Default Restoration Progress Continues
The white is now sprayed. Much better coverage than the yellow. As my friend says, "two to go, three to show."
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 10-24-2011, 11:19 PM
Default Parts, parts and more parts
Painting parts, parts and more parts. It could be yellow fever.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 10-24-2011, 11:21 PM
Default Opps
Starter generator on a 149 is suppose to be black, right?
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
