Greg Rozar AKA- CubDieselFan
Old 09-22-2017, 10:54 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Originally Posted by Workinprogress View Post
Sorry progress slowed. Spent a couple nights practicing stick welding. Was able to get one hitch welded. Then wife started me on another project.
Last year she copied a painting on plywood with exterior paint. We hung it on the side of the garage.
This year she did three more. Since it was time to replace clap boards i spent the past weekend removing clap boards and putting up paintings.
Now I am on new clap board duty before cub time!
Attachment 87542
Ever get passed The Clap so you can finish your hitches? How's the buzzbox working out?
1- 1200 in pieces
1- 1864 in pieces
Old 10-05-2017, 05:53 PM
Workinprogress Workinprogress is offline
Sorry no updates. Too many other projects and multiple late nights at work.
Hopefully back onto hitches this weekend!
1512 with CADloader 507, CADdigger 508 and 3 pt
1711 with KT17
782 with KT17 and 3 pt
104
Old 10-07-2017, 06:29 PM
Both hitches welded up. The tombstone did a pretty good job welding. Welds aren’t that pretty but they apprear strong and had good penetration.
Access hole for linkage pin drilled.
1711 with KT17
104
Old 10-07-2017, 07:17 PM
Progress continues!
1711 with KT17
104
Old 10-08-2017, 05:58 PM
Rear arms built!
1711 with KT17
104
Old 10-10-2017, 06:58 PM
Small steps every day!
Finished the second top link bracket. Welding getting better with tombstone.
Adjuster parts before grinding and welding.
Adjusters for rear lift arms.
Adjusters on threaded lift arms.
1711 with KT17
104
Old 10-10-2017, 09:53 PM
john hall's Avatar
looking good!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-13-2017, 08:10 PM
Rescue11's Avatar
Do you have a pattern for the lift rod? I have a new 1 I'd like to sell. It's from my 1864, it was used twice and then I modified the 3pt.
1- 1200 in pieces
1- 1864 in pieces
Old 10-15-2017, 08:54 AM
Few more step!
1st coat of paint.
Thanks on the lift rod but I have one from my 1512 build which I used as a template.
1711 with KT17
104
Old 07-09-2019, 08:55 PM
Well it has been a while but 1st install and test is complete!
I put the 3 pt onto the 782i rebuilt. Made a few passes on the driveway with the grader blade. All seemed good!
1711 with KT17
104
