Greg Rozar AKA- CubDieselFan
Old 08-07-2017, 09:32 PM
MI Cub MI Cub is offline
You can use a some pieces of 1/2" pipe and rod or bolts for the hinges.
Nothing fancy but it will work well and be strong.
A spear/ notched on top for the rope trip will make you a nice setup.
That is what I was planning on using for the hinges, it may have been done before in my shop (I'm a pipefitter/welder, so I use what is handy/free). I was thinking of notching the top of the bucket and putting a spring on the catch to keep it from dumping when I hit a bump. Such a simple concept that I completely overlooked while knee deep in the project. It goes well with my motto though. K.I.S.S. keep it simple stupid, I should put that on the shop wall above the fab table.
Matt
1650, 44A deck, front blade, QA42A snow thrower, 1A tiller, 10" brinly plow, brinly cultivator, home made rear bucket, home made sleeve hitch.
Old 08-07-2017, 09:36 PM
9 out of 10 times, you only realize how much simpler you can make something only AFTER you build the first one. BTDT time and again.
Old 08-07-2017, 09:49 PM
Yes sir! It's a fine line for me between over thinking the project and jumping in with both feet before making a sketch. Maybe the older I get, the better I'll be able to balance it?
Matt
Old 08-11-2017, 09:16 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
https://www.youtube.com/watch?v=p9mWtsNTCTk
Didn't have any front weight, so yea. But this will handle anything you can put in it. I wanted something that could dump higher off the ground than a trip bucket.
Your bucket looks nice, and if you don't mind scooping it off, it sure beats a wheel barrel.
1- 1200 in pieces
1- 1864 in pieces
Old 08-19-2017, 12:18 AM
Now that's a nice setup!
I've noticed with mine already that a bucket full of dirt makes the front end VERY light. I'm thinking there's going to be a weight rack made before long here.
I just put the material on my welding bench to make hinges and a trip for the bucket. I'm not sure how much is going to get done this weekend though, taking my son to the national tractor pulling championship tomorrow.
Matt
