Greg Rozar AKA- CubDieselFan
Old 11-17-2017, 02:44 PM
jah457's Avatar
jah457 jah457 is offline
Default Rockshaft Arms 1650 vs. 1572
I installed an older QA42 snow thrower on my 1572 today and went to connect the lift rod and finally realized the rockshaft arms on all my older cubs i.e. 1650 point upwards, but on my 1572 it points downwards. Is this by design on the 1572, or did a previous owner switch the orientation from pointing upwards to downwards on my 1572?
I ended up going to a cable lift that goes to the a pulley I installed off the rear axle, and then comes back to the rockshaft arm in order to get lift. I will take some pictures and add them this afternoon to better show what I mean.
_________________
Godspeed,
107, 109 (2), 125, 129, 147 (pieces), 149, 1650, 1650 w/ Johnson FEL, and 1572 Diesel, 1958 Farmall Cub
Old 11-17-2017, 02:52 PM
Sounds like the rockshaft was installed upside down.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 03:14 PM
You connect the lift rod to the rockshaft arm sticking out the right side next to the cam lock knob.
Tim, I do not think you can put that on upside down but if so ,knock out the pins and point er up!
Up to 530 and counting...
Old 11-17-2017, 04:38 PM
Terry C's Avatar
Terry C Terry C is offline
1572 brakes are in the way of a top arm
Rod goes on bottom.
Google 1572 and there are some pics of the arm
Not Lew, the OP should look at the pics
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-17-2017, 04:45 PM
Terry C's Avatar
Like this here one
File Type: jpg 549EFF1D-A746-4490-9DFE-6C50EFAB4346.jpg (36.0 KB, 143 views)
Terry
3225
Old 11-17-2017, 08:59 PM
V30crewcab V30crewcab is offline
as far as I know, all the supers had the arm at the bottom.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 11-18-2017, 06:38 AM
jah457's Avatar
Question Rockshaft pushes forward instead of pulling backwards
Guys, thx for the replies to confirm the 1572 Rockshaft Arm is supposed to point downwards. Forgive my ignorance, but as in the attached picture when the arm pints down it pushes forward like the green arrow, not pulling backwards like the red arrow (e.g. my wide frame 1650).
On the 1572 it doesn't appear to have a hole in the internal Rockshaft arm to use the lockout pin like the older wide frames where you could get both push and pull by inserting the lock out pin. With the 1572 having a free floating Rockshaft, it doesn't pull backwards which is needed to lift my snowblower.
QUESTION: Is there a way to Lock Out the 1572 Rockshaft arms so I get both push and pull?
_________________
Godspeed,
Old 11-18-2017, 09:22 AM
Problem is that you are supposed to use a 450 blower on that tractor. The pulley and cable that you rigged up may be the best way to go.
I am going to put this in the implements section. I think you'll get more help there.
Old 11-18-2017, 11:02 AM
jah457's Avatar
Thx Sam Mac
_________________
Godspeed,
Old 11-18-2017, 11:10 AM
Yeah..... that blower wasn't meant for a SGT.
You aren't going to get the "pull" style action out of that lift system outside of what you did.
