Greg Rozar AKA- CubDieselFan
Old 08-22-2017, 04:53 PM
Rainman4820 Rainman4820 is offline
Default 1641 Starting Issues
Hello all, my 1641 has been running with no issues. Today however, when I turn the key, I just get a low pitch whine like the starter is trying to turn the engine over. It never fires and it seems as though it is turning too slow to make the engine crank. Battery is fully charged.
Any thoughts on where to start diagnosing?
Thanks in advance for your comments.
Old 08-22-2017, 05:38 PM
I would suggest, you start with your Battery Cable connections. Make sure they are clean, bright, and tight. This is for both cables, both ends.
Roland Bedell
Buy: Made in the USA
Old 08-24-2017, 09:46 AM
Ok thank you for the response. I removed all cables and all connections are new or shined up and tight. Battery is at 13 volts. Still whining. Sounds to me like the starter is turning but not engaging flywheel. I have a short video of the sound during starting at the youtube link below. (disregard the humming sound in the background...I have a battery charger running) I appreciate your input.
https://youtu.be/vVml8M_UJyI
Rainman
Old 08-24-2017, 09:50 AM
Sounds like the Starter Bendix is not engaging the Flywheel. Looks like it is time to pull the starter. Examine the Bendix for dirt and debris. Clean if necessary. After cleaning, the Bendix my need some lubrication.
Roland Bedell
Old 08-24-2017, 10:08 AM
Terry C's Avatar
Terry C Terry C is offline
It either needs cleaning and lube or a new bendix. I have had a couple come apart at the joint between the teeth and housing.
May be a good time to remove engine and give it a good cleaning. It's easier to remove the starter that way. I've done both ways but if it's been awhile since you cleaned the engine fins, now would be the time to pull the engine. Good luck
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-24-2017, 10:11 AM
I agree with Roland, --- it also sounds slow.
As a test, put a jumper cable from the positive battery post right to starter terminal and see if it starts.
if no joy, do as he suggests and remove/open up the starter and investigate.
Old 08-24-2017, 11:06 AM
There is an inspection cover on the blower housing next to the starter, remove it to see the condition of the bendix , more than likely it is broken as others have said.
Up to 530 and counting...
Old 08-24-2017, 05:48 PM
Default 1641 Starter
Ok will do... many thanks for the responses
Old 08-24-2017, 08:14 PM
My bet is that the teeth are gone on the bendix you could also be missing some teeth on the ring gear on the flywheel. BTDT on a 1641
Old 09-02-2017, 02:17 PM
Default Starter
Ok, I have checked all the voltage issues and am now convinced its either the starter, bendix or God forbid the flywheel. I am slower than most and just getting around to removing the starter. (I do plan to remove the inspection cover first to see what the bendix looks like)
I noticed that I can only access one of the two bolts holding the starter in place. Does this mean I have to remove the shroud on the engine to access the upper bolt? I have 2 service manuals and neither one addresses starter replacement so I appreciate your input.
Thanks
Rain
