106 head studs and spacers
I am working on a 106 with a k-241 i need to know the length of the head studs and length of spacers for under gas tank and heat shield with low boss? Do you use two nuts
The best I could do is this. "Assuming" you have a Kohler K241-46700 engine, you will need:
(A) 237277-S Stud (which is NLA, only used and NOS can be found) (B) X-400-71-S------> 25-112-14-S Spacer The part numbers did not give any specifications as to dimensions.
I tried looking it up also, with the same result.
Here's the deal, lay the head on the motor and stick something down the hole to get a measurement. Studs are easy to get. McMaster Carr carries those. If you are going to make your own spacer, you only need room enough to clear the fins. As I recall, there is only one nut. You cold also just do all bolts. Studs aren't necessary. |
ok thanks guys for info
My Auction 100 needed a head gasket. It was a high boss head. I replace the head with a low boss head. I used these spacers:
The one on the left was used as a washer between the head of the bolt and the top of the air shield. The one on the right was used as a spacer between the head and the bottom of the air shield. I found a something that will work on McMaster-Carr website: Thin washer-93320A300 Thick spacer-92415A129 I added another flat washer between the top of the spacer and the bottom of the air shield. The McMaster-Carr spacer are .625 thick. They should have been .688 thick.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I would change all the studs over to bolts. You can use grade 8 bolts or Kohler bolts. Both of my 100s are just bolts holding the head on.
So how is your fuel tank mounted?
Probably just with the bolts. I think that's how we did the 126 of yours. (Or was it the 106?)
Using bolts. There should be 3 head bolts and two 1/4 inch studs on the fan shroud that holds the fuel tank mounting bracket on.
I would be afraid studs could be too long unless you modify the studs.
