Greg Rozar AKA- CubDieselFan
Old 09-04-2016, 08:58 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Originally Posted by twoton View Post
Hmmm... So your .01" camshaft shim is oversized?
Is it really critical David? As long the camshaft end play is set between 0.005/0.010 I see no problem at all. A +/-0.0004 difference for a shim is nothing to worry about, most mechanic only use 0.001 graduate micrometer not Lab certified and tested 0.0001 graduate like the one I use.
Last update: Rebuilt kit delivery expected 6 September
Gilles.
1963 100 (red)/in storage
Old 09-04-2016, 06:04 PM
twoton twoton is offline
Not at all Gilles. As a reference, the .01" precision shims that McMaster-Carr sells are listed with a manufacturing tolerance of +/- .001" so your .0004" is well within that range. I just found it curious... I would normally assume that due to wear the shim would be a bit undersized, but you know what happens then?...
Old 09-04-2016, 06:38 PM
OldSkull's Avatar
Well I can't resist a occasion of picking my ultimate precision tool out of my tool chest and check again that shim...
My Canadian tire home brand "Mastercraft" $30 Caliper!
I'll be damned! 0.0105! But something strange happen! The Good and tasty Chocolate/Caramel cake
the caliper was sitting on disappear just after the picture!
A little heat and few "dong" to remove the "Ding" in the fender/pan
I did more on the fender pan but I keep that story for latter, time to close the shop and answer George nipple story in another thread...
Gilles.
Old 09-07-2016, 09:24 AM
OldSkull's Avatar
On my way to cross the frontier and pick up parts I order for my engine, I'm done, my bucket list is empty, here what I spend yet:
-"The man one stop shop" Kohler K321 Master kit :$115
-"P&P engine" (Many parts) :$205,50
-"J David Kirk" counterweight and Transdencer II $71
Add to this the machine shop fee, new head bolt, gasket sealer, Valve "Rubbing" compound, assembly oil, break in oil...Bla bla bla. (Not counting the extra tools I purchase because I'm tool addicted..) I didn't cut corner..
Gilles.
Old 10-05-2016, 12:48 AM
OldSkull's Avatar
About time I post pictures of my rebuild progress, the engine has been sitting like this on the bench for 2 weeks...
You can see the crank shaft counter weight, the oil I use and a picture of the partially assembled engine , only missing is a picture of the Cam and crank shaft TDC alignment, it's in my inspection camera (Borescope). I include a picture of a Harley Davidson piston who show how I install rings on piston on every engine I work on.
Gilles.
Old 10-05-2016, 01:16 AM
Your doing good Gilles!!
Old 10-05-2016, 08:17 AM
We run the same break-in oil in all the engines we build, it's good stuff.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-05-2016, 09:52 AM
OldSkull's Avatar
Thanks Jon,! Easy going so far
Most guy at Napierville race track use this stuff, I though if it's good enough for a 2000hp 10 seconds run dragster engine on the dyno,
it most be good enough for a 14hp Kohler flat head.
Gilles.
Old 04-01-2017, 07:02 PM
Lookin' for some updates here Gilles...
Old 12-18-2017, 05:33 PM
....... David Kirk" counterweight.....
.....crank shaft counter weight.....
Hey Gilles, still wondering how that Kirk Crankshaft Balance Plate Kit;
http://www.kirkengines.com/#Products
is working for you???
Any one else have experience with this kit?
