Greg Rozar AKA- CubDieselFan
Old 03-13-2018, 03:34 PM
2wheelsadam 2wheelsadam is offline
Default Sleeve hitch assembly 1650
Wanted everything needed to install sleeve hitch on a 1650 with hydraulic lift. Must be willing to ship to U.S address and a bill of sale because I will have to pay tax when coming back into Canada.Thanks also a rototiller and gear box if available.
Old 03-14-2018, 10:07 AM
mortten mortten is offline
There are two different styles that could be on your tractor. Serial number 616145 and below uses the shaft style. Above that uses the bolt style.
Doug
QA-36A
42" blade
Old 03-14-2018, 04:06 PM
Default Tiller
Well that’s sure good to know there’s a difference. So mine would be a shaft style. Know what is difference between the 2 �� sorry I’m learning.
Old 03-14-2018, 06:24 PM
If there are 2 bushings spun welded to the inside of the top of the frame rails in the back, then you have the type that takes only a piece of round rod w/holes for cotter keys.
If there are no bushings, then you need the Frankenstien bolts to mount it
Old 03-14-2018, 06:40 PM
Default Hitch
Ok thanks. I will need to have a look to make sure. 👍
Old 03-19-2018, 09:00 AM
Default Hitch
Ok I have found sleeve hitch parts thanks. Now just looking for reasonably priced tiller gearbox and bracket.
Old 03-19-2018, 09:01 AM
Do you have a tiller?
Old 03-19-2018, 02:14 PM
Default Tiller
Yes I have tiller.
Old 03-19-2018, 03:21 PM
There is a gearbox in the for sale section....
Old 03-19-2018, 06:16 PM
Default Gearbox
Yes I seen it but a little to much for me. Nice unit but by the time I transfer from Canadian to US dollars plus shipping I could almost buy another tractor🙄 looking at 400 Canadian dollars
