very nice work
Good job, Daniel! Thanks for the update and pics.
Allen Proud owner of my Original! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator |
Nice work. Mine is gonna need that soon. It look like you didn't remove the cutting edge. If its not too late, you should. There's probably some rust under it that needs attention too.
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
I removed the cutting edge last summer and flipped it (new carriage bolts/washers/nuts.) It's getting painted over.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Daniel,
Nice work! I just blasted my blade a year ago, but didn't remove the 3 bolts that hold the blade rod on. So here is what it looks like, even tho I used rustoleum as primer and painted over it with tractor rattle can paint. You can see the rust is bleeding down the housing. Not a big deal, but eventually I will take off the rod support and clean and prime/paint it up. You have done a really good job on your blade. Thanks for the pics!
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
The blade came from a 1000 that the PO just bent the narrow frame subframe arms apart so it would fit his 1000. When I got it home, I just took a persuader to it and bent the arms back. Don't have any idea if it had been used with a lift. I do know that it works great. Need to take the broken skid off the blade and replace with two new ones that I got from a sponsor here. Good luck with yours!
I have no idea if it were angled with a hydraulic cylinder. Since I don't have anything (or seen anything) with a hydraulic lift, I don't have a clue. Being in a state that seems to have very few older cubs, I rely on OCC to learn about cubs. I learn something almost everyday. Now I will look closer at snow blades and how they are hooked up.
Blade is looking good, it's amazing how much snow they'll push.
After removing the rust (sandblasting, electrolysis, vinegar, molasses, grinder etc..) you should treat the metal with phosphoric acid. Your local Home Depot or Hardware store will have it for cleaning concrete. The key to this is to keep it liberally wet for at least 20 minutes so it has a chance to work its way into the rust and do it's job. Once it is treated be sure to clean the metal really well and remove any residue from the acid and then sand it or you will have adhesion issues. The rust will be black and inert so it shouldn't come back. BTW, Rustoleum is an oil based paint so if you try to top coat it with something else it won't last long.
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
Thread Tools | |
Display Modes | |
