painting tips and help
I am going to use IH brand paint for my 1650. I've read a lot of 8-4-1 ratio and even 4-2-1. Im gonna be using a 23 gal compressor. I want to use Napa brand reducer and hardner if possible. I have a air gun. I see some write about spraying one coat, waiting 10-15 minutes then spraying another coat. Is there anything I am missing?
Thanks, Nate |
Compatibility?
Pour a small amount of the ih paint into a separate container and make sure it mixes and stays mixed with the napa brand reducer
Two or three coats
I would recommend doing one coat first, a light coat also called a tack coat, if u try to cover it in one you are going to run it for sure
Mix very well and take your time and do many light coats or it will run. 10 to 15 minutes inbetween coats i do 4-1-1 paint- thinner - hardne. Works for me
882 diesel, 782ccc, 782ih, 102, 62 original, 108 x2, 124, x3 vtwin 82 seriers pullers, 1 wide frame puller project |
like what was said. lots of light coats. I call the first one a dust coat. (tack coat) if your metal is cold it will take a lot longer between coats. the metal should be 65deg. or warmer. if its cold in your shop the flash time will take up to an hour , not 15min.
if you start getting runs , just stop! once dry, wet sand the runs off with 600 then the hole tractor with 1000 grit. then start painting again.
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
do I need a filter for the compressor to trap condensation?
Thanks for the help. It's really appreciated. |
The number for the Napa reducer is CR733 at my Napa a qt is 15.00. I don't use mixing cups and things. I just eye ball it. You want it alittle thicker than water.
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
Yes, it is recommended. At the end of your hose farthest away from the compressor. Cheap insurance. As mentioned tackiness can vary depending on weather conditions. Just feel it with a touch of your finger I'm NO pro but I took my time (1st. Time) but one day it was tacky in 20 min. & then one day it took 45 min.. You tube is a great source to find out about spray painting, setting up your gun etc.. Look up cub cadet restoration
It dont cut grass, but its yellow. |
I used a couple pieces of junk metal & cardboard to get the feel of it, then found out what distance was best.
If I could do it than anyone can. NIK,
if you were close, Id paint it or help to show you how to do it.
asking questions is good but you really only can learn by doing it. painting is a hands on tough trade. all brands spray diffrent , all guns spray diffrent, and so on.....
