Greg Rozar AKA- CubDieselFan
Old 03-06-2013, 03:20 PM
1650noob 1650noob is offline
Default how to restore cast iron 1650 nose
I've worked with restoring metal parts. But am a bit new to cast iron. I want to start restoring my grill off my 1650 but wanted to know whats the best way of removing paint and repainting the cast iron grill?
Thanks,
Nathan
Old 03-06-2013, 03:32 PM
bluesman bluesman is offline
Thumbs up Grill shell
Nathan,
I just finished doing this. My goal was to save the rough as cast look so I just used stripper on it. Came out looking great. Good luck with yours
Dave
Old 03-06-2013, 06:38 PM
CadetTY's Avatar
CadetTY CadetTY is offline
80 grit on a d.a use finishing putty to fix deap scratches or dings or small cracks. Then 180 gritt and prime. Couple good coats let dry 400grit the primer and reprime again then 400 grid and paint
882 diesel, 782ccc, 782ih, 102, 62 original, 108 x2, 124, x3 vtwin 82 seriers pullers, 1 wide frame puller project
Old 03-06-2013, 10:39 PM
ok, thanks guys!
Old 03-06-2013, 11:35 PM
cubby102's Avatar
cubby102 cubby102 is offline
Wire wheel on a drill works great if you don't want chemicals but still want the rough cast look
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
