taking old paint off
whats the easiest way to get all the old paint and rust off? i was using a grinder with a wire brush attachment but at that rate it seems like it will take me years to get this machine ready for paint. any suggestions?
Aircraft paint stripper from your local auto parts store. As for rust elbow grease or electrolysis rust removal.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I also love electrolysis, but about a 30 gal rubbermaid container is the biggest vat I have at the moment. Even with using electrolysis you need to tire a wire brush afterwards to get it shined up good.
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
SANDBLASTER.....removes paint and rust!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Just keep the sandblaster away from the engine, trans, and anything aluminum.
ok thanks guys. I picked up the aircraft remover but wasn't too impressed with it honestly.
I bought a rubber 42gal. trash can, slopped the stripper on, let it sit for 15min. dropped it in the trash can, hooked up the battery charger & in 2 days was fantastiko. I then power washed the whole nose of the #122 & came out super. |
how long did you let it set? And I found the only way that tail strip stuff worked really good, was to get a visible paste on it and let it sit, not just wipe it on.
Some parts of a tractor with a good paint seal in areas is needles to be removed. I feather out the paint and recomend a primer sealer before primer. You will have the best results removing any paint with a 4 inch flap wheel. Check the grit for what you need.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
The temperature of the stripper and the room temperature are both VERY important.
Chemically, this stuff just about "shuts off" under 65. A fairly thick and consistent coating is needed so as not to allow the stripper to dry out before it has a chance to penetrate the paint layer(s). |
Thread Tools | |
Display Modes | |
