Allen,
Do you have the correct bracket? Is it the one that you have to remove the right foot rest to install? Mike,Like I need more hahah ho ho Working across the street from the kinnelon tower,nice view. I see your cubs from there heheheheh
Lew, here's a pic of the bracket. The manual says to remove the right footrest, to install the sub frame.
Allen Proud owner of my Original! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator |
If you have the one with the hole on the bottom you have to take off the foot rest. But if you have the later one you'll have to cut of the little hook part of the lift plate to make it clear the foot rest.
Here's a picture of a web site . The correct one is on the right. The left one was modified(hooks cut off). You dont have to remove the foot rest to install the sub frame. It's definently easier with 2 people. |
Thanks Mike, I'll check my bracket.
Mike, my bracket is like the right one. It doesn't have the hole in the bottom.
So someone cut the bracket because they didn't want to take off the foot rest. That is still OK but it might work loose because the ears are shorter. Still I think the subframe should fit between the bracket and frame. If not try to loosen the foot rest and mount the subframe then retighten the foot rest.
Thanks Mike, I really appreciate it!
On another note, we took the blade to the sand blaster in Fayetteville. Should have it back within a week.
Keep us posted.
Sure thing, Mike!
Allen,
When I put my blade on my 73, it pushed the footrest out a little...that would explain the washers for spacing, which I didn't bother with. If your bracket has been cut to slip over, then just make sure your U bolt nuts are tight (maybe with lock washers) and you should still be alright. Can't wait to see your pics, but I'm guessing that you are even more excited to put it to work!!! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Thread Tools | |
Display Modes | |
