Greg Rozar AKA- CubDieselFan
Old 12-23-2011, 07:29 AM
gost530 gost530 is offline
Default Balance Gears
I know there are a lot of opinions abnout balance gears. Many recommend leaving them out, however a friend tried this option and advised that while at low rpm the engine shook so bad that he couldn,t keep the screws in the carb tight. I do see that one of the suppliers offers a counter weight which can be installed on the crank in lieu of balance gears. Does anyone have any experience with it? How difficult is it to install? Since I plan on having the crank turned would it be an option to have it balanced at that time? Thanks Gary
Old 12-23-2011, 10:35 AM
I would pull them and not put anything in their place. I don't see the point of putting something back in to blanace the crank. Maybe someone else has used them. I know lots here have pulled them and never worried about their engine again.
Old 12-23-2011, 11:02 AM
One shouldn't be running these air cooled engines at low speed anyway, they should be run wide open for maximum cooling. I haven't heard of anyone using an aftermarket bolt on weight here on the forum.
Old 12-23-2011, 11:24 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Sounds like he has more problems other than balance gears and as for the bolt on weights, they being use in mostly pulling engines, not saying you can't use them here, I think he has other problems, could be a number of things, all the way down to the drive shaft, to even being the motor not bolted down to the frame.
Donny
Old 12-23-2011, 11:50 AM
red56turbo's Avatar
Those gears earned the nickname "grenade gears" for a reason. When they go, they unfortunately usually take the block with them. Most pull them and leave them out. Alot feel they didn't help much with vibration anyway. I don't know of anyone adding balance weights to the crank. It's really up to you if you want to. Without any experience with it, I wouldn't really know what to tell you either way.
Josh
Diesel Cub Cadets...........
Old 12-23-2011, 12:03 PM
cubs-n-bxrs's Avatar
I have actually done this static balance method and it worked just fine. I built a motor for my 124 from various parts and pieces and when I fired it up for the first time it shook so bad it was hard to keep your hands on the wheel from the vibration. I did the static balance method that Brian Miller has on his website. Actually had a phone conversation with him on how to do this. All the parts and pieces should weigh a certain amount and it turned out my crank weighed considerably less then it was suppose to. I built the weight plates and got the weight correct and viola the thing runs like the energizer bunny now.The plates were mounted to the sides of the balance lobes and the screws are red loctited.It should be noted that I have access to a full machine shop at work. And by the way I have hammered on that 124 for 3 yrs now and been to a have been half dozen plow days. Best I can tell you is put it together without the weights and see what happens. If the vibration is over the top pull it back apart and static balance it. Do not let others tell what you should or shouldn't do to your tractor. It's all a learning curve. Have fun with it
Old 12-23-2011, 04:35 PM
Flatbedford's Avatar
Is it worth opening up the engine only to remove the "grenade gears"?
Steve,
Former multiple 149 owner.
Old 12-23-2011, 04:40 PM
jeffscub's Avatar
jeffscub jeffscub is offline
it's easier to tighten screws than it is to replace an engine. air cooled need to run WOT. leave the balance gears out. they're a ticking time bomb!!! just my two cents worth. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 12-23-2011, 04:43 PM
jeffscub's Avatar
YES, the bottom one will come out no problem. make sure you get ALL the shims out. the top one will come out via a well placed chisel punch and hammer. as with the bottom one, remove all the shims and MAKE SURE TO GET ALL THE "SCHRAPNEL" OUT OF THE BLOCK!!!!! jeff
Jeff
Old 12-23-2011, 04:53 PM
I had the engine out of my 125 last summer. Too bad I didn't know about this then.
Steve,
