#21
I have used it countless times over the last 35 years and never ever ever had an issue with using ether in any engine I have used it in gas or diesel. When used correctly and under the right circumstances there is no problem using it. I will continue to use it without issue Im sure,.. But thanks.
#22
#24
Is it a Courage....? = Valvetrain...
#25
About time someone mention it...What is it? A courage? A 7000? A Command? A twin or a single cylinder? Still under warranty or not? First owner?
Like previously mentioned all new Cub Cadet lawn tractor came with a 3 years warranty, unless the OP buy his LT used or from a "Good fellow" behind a local bar.... He better let a dealer working on it.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
#26
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#27
Ditch the either.
Use carb cleaner instead |
#28
No, no, no!!! That's terrible hard on all the parts! Stop using that too.
Ether is alright to use sparingly guys......but really, using some gas down the throat of the carb is pretty easy. Tougher on the K series. But honestly if you can't tell if you have a fuel or a spark problem and are using ether to test with...... put the tools away and take it to a mechanic. You don't know enough to fix it if you can't figure at least that much out. |
#29
If it's still under warranty, don't jack around with it. If they find out you've been messing with it, that may void your warranty.
#30
Thread Tools | |
Display Modes | |
