Greg Rozar AKA- CubDieselFan
Old 05-19-2018, 10:17 AM
I call bs on that.
I've done this before looking for an AC voltage leak. It's normal for a meter to pick up a fluctuating AC voltage, but not a constant one. You put the meter on the battery on AC volts, and it may sit there and roll around some numbers..... but it typically won't show a constant AC voltage. I've also seen instances where the meter would hold like .5 AC volts or under. Again, that is normal. Most service manuals give an allowable limit. 24, 25, 26 volts?!?? NO. But, I'm still not convinced. That is a huge amount, and should be causing major issues. I've seen AC voltage leaks under 2/3 volts burn up ignition systems.
I know and understand how a rectifier works, and I get what is being said.... but he shouldn't be getting a reading that high, unless 1.) There is a major issue, or 2.) His meter is junk. I'm leaning toward 2....
To the OP: again, check using a different meter. I really think it's the meter.
Old 05-19-2018, 04:58 PM
Terry C's Avatar
Terry C Terry C is offline
I call bs on that.
You are correct (again)
I just tried my Fluke set on ac,on three tractors.
.03 was the average.
I was curious cause I had never tried it
I did expect a little more, not what the OP had, but a couple of volts maybe.
I was wrong. Wasn’t the first, won’t be the last.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-19-2018, 05:16 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Terry, I checked mine as well with the same results. I did have a 1 volt spike when touching the B+. I am charging the 97. I will post a waveform later.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-19-2018, 05:22 PM
Terry C's Avatar
Cool, I’ve always wanted a 97.
Terry
3225
Old 05-19-2018, 08:19 PM
Shrewcub's Avatar
Not much there. Just a few spikes less than 200mv.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 05-19-2018, 08:25 PM
Looks like a normal heart beat to me.
Up to 530 and counting...
Old 05-19-2018, 08:28 PM
Shrewcub's Avatar
Just a happy kitty purring away!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 05-20-2018, 09:05 AM
Terry C's Avatar
Thanks for showing us that Travis!
The battery must fill in the gaps too well to see them.
I still have meter envy though.
Terry
3225
Old 05-20-2018, 10:39 AM
mrbill65 mrbill65 is offline
It could be my meter it is a $50 model from Lowe’s always seems to work for what I need it for which is simple trouble shooting. I don’t have another meter handy but will try and borrow one and check it again. Or not and not worry about it the mower seems to run fine I ran it for 2 hours cutting the grass with no problems after swapping out the bad rectifier.
Old 05-20-2018, 11:24 AM
Terry C's Avatar
Glad it’s working good. Sorry about getting sidetracked about Flukes.
Terry
3225
