Greg Rozar AKA- CubDieselFan
Old 02-26-2018, 10:20 PM
Did you check your relief valves? There is an access panel on the side to check them. You might spray some PB blaster with the nozzle on them to see if it frees them up a little and hopefully solves your problem. I would have suspected the spiral pin, too, but since you say that looks great, the relief valves would be my next area to look at.
Old 02-26-2018, 10:41 PM
He only checked the front pin....
Old 02-27-2018, 02:42 PM
kyumanaz's Avatar
kyumanaz kyumanaz is offline
Default canfield
I live in Canfield, Ohio. It's near Youngstown. The pins all look good so far. It acts like it isn't getting enough fluid. How do I get the correct hydro fluid filter number? I am wondering if the guy at the parts store gave me the wrong filter. It was a bit sloppy, but worked before I changed the filter and fluid, then worked a bit and started giving me problems.
Old 02-27-2018, 02:44 PM
kyumanaz's Avatar
Are the relief valves the bolt head looking things with the nipples in the middle that move?
Old 02-27-2018, 02:53 PM
Yes.
Filter is a Wix 51410, Napa 1410, or you can go to CCC and get one.
Old 02-27-2018, 04:00 PM
kyumanaz's Avatar
Default Bottom end
If I drain the fuel and oil, can I tip the tractor up vertical on the rear tires to gain access to the underside and check the rear of the shaft? I'm disabled and its really hard to crawl under things to work on them. Also, where can I get a good Hydro diagram for the 127? I have a diagram for about everything but that. Thank you all for your help.
Old 02-27-2018, 04:21 PM
As long as you're under half a tank of fuel it won't leak when you stand it up. Unless you're planning to keep it standing up for an extended period of time I wouldn't worry about draining the oil.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-27-2018, 04:51 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=25534
Old 02-27-2018, 08:03 PM
Also, where can I get a good Hydro diagram for the 127? I have a diagram for about everything but that.:
What do you mean by diagram? A parts blowout? Or a hydraulic diagram? Or a service manual?? Not sure what kind of diagram you are needing....
Todd..... I had forgotten about that deal on your 125. Made me laugh again. Not at your expense, but remembering back how much time and effort went into diagnosing it.
Old 02-27-2018, 08:06 PM
Start it. Do you see the driveshaft spinning?
