Greg Rozar AKA- CubDieselFan
Old 09-29-2017, 06:13 PM
kish-81's Avatar
kish-81 kish-81 is offline
Default Engine pulley loose - LTX 1042 KW
Good evening all,
After mowing today, I was idling the tractor while blowing off the clippings and I saw the drive pulley was "wobbling" at idle. After shutting down, I noticed that the split washer on the bottom of the pulley wasn't flat (i.e. tight) and there was play in the pulley.
So I got out the large vise grips to clamp to the shaft above the pulley to keep it from spinning to tighten this bolt. After 10 minutes of the bolt spinning, it does not appear to be getting any tighter.
Is something spinning internally on this engine pulley that I can't see? If so, how do I tighten this bolt?
Dave
Dave
now own a LTX 1042 KW
formerly had a 1620 Hydro
used a 1450 Hydro (dad's machine back in the day)
Old 09-29-2017, 06:19 PM
Possibly you need to remove the bolt and see if the threads are stripped?
Old 09-30-2017, 09:25 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Originally Posted by kish-81 View Post
Good evening all,
Dave
If I was you I do that:
Remove the belt, unscrew that bolt (2) check the condition of his threads, remove the pulley (13) and the spacer (31) check for any damage to the pulley keyway and structure, check the spacer condition, check the crankshaft keyway, use a 7/16-20 tap to "refresh" the shaft threads.
If at this stage you didn't find anything was wrong, put a new 7/16-20X3.5" gr5 bolt, go to your local church and light a candle, may God be with you, Amen.
PS: The OEM bolt got red threadlock on it...(http://www.cubcadet.com/webapp/wcs/s...rocessARIParts)
Gilles.
1963 100 (red)/in storage
Old 09-30-2017, 09:31 AM
kish-81's Avatar
So last night I did notice that there is what appears to be a keyseat at the top of the pulley. Does this indentation act as the "key" on the inside of the pulley?
Dave
Old 09-30-2017, 09:57 AM
OldSkull's Avatar
The Kawasaki (FR600V) engine in your tractor got a keyway crankshaft so the pulley must have a keyway somewhere! To my knowledge no vertical crankshaft engine in a lawn mower tractor have tapered shaft. The are cheap but not "That" cheap.
Gilles.
Old 09-30-2017, 12:27 PM
kish-81's Avatar
Just came back from local mower shop; he had a Grade 8 bolt in stock, so I went with it.
Old bolt did show signs of stripping, but I did not have time nor a tap set, so I installed new bolt. This one appeared to tighten up, but I'm not happy with the wobble at the bottom (deck pulley) end. Either will replace pulley this winter or will take to shop for permanent repair. But looks like I can finish this mowing season.
Thanks for all your input!
Dave
Dave
Old 06-15-2018, 08:18 PM
kish-81's Avatar
So the saga continues....drive belt broke today when the wife was mowing. Dropping the engine pulley to get ready for the new belt and I see a lot of damage to the keyseat on the engine shaft. But if the key in the engine pulley is OK, I'm not too worried. Looking inside the pulley, I see the "key" - it literally looks like someone dropped in a short weld as the key! (see photo)
Should key in the pulley truly be square-shouldered? Or is this the result of the damaged keyseat on the shaft and my earlier wobble issue?
Dave
Old 06-18-2018, 12:50 PM
kish-81's Avatar
And a photo of the keyseat. 😬
File Type: jpg 0EAE81DC-849F-4C65-A2AC-409D14AC3D0B.jpg (16.2 KB, 28 views)
Dave
Old 06-18-2018, 01:00 PM
cooperino's Avatar
And a photo of the keyseat. ��
Thats trouble.. the key made that mark there.. Not suppose to look like that.. The key way should be the same front to back.
Not sure if you know how to weld but you could run a bead to fill in the void then you need to grind the keyway and shaft back into shape.
Old 06-18-2018, 01:46 PM
Keyset hell!!
That's the crankshaft!!
How deep are your pockets?
And, WTH did you hit??
