Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 08-14-2017, 09:47 AM
familytime familytime is offline
Default WG600 carb
After putting a new distributor in my issue with the engine cutting out after getting hot has been cured. I'm still dealing with the surging issue. Sam Mac had a post about the governor spring going into a harmonic vibration, I cured this issue by sliding a short length of weed eater fuel tubing over each end, it is just enough to cure the vibration. Now I only have an issue when trying to maintain a smooth idle. If I pull out the choke about a quarter to half inch, it runs and holds idle just fine. I've tried tuning the needle valve but just can't seem to get it to run smooth that way. I have cleaned the carb 3 times. There is no issue with the fuel system otherwise as the fuel tank grommets are new, the shut offs cleaned, all new fuel line, new fuel filter, and new pump.
Old 08-14-2017, 10:49 AM
Terry C's Avatar
Terry C Terry C is offline
As far as I know there is no carb kit for that carb. I gave up and just bought a new one. They are not that bad. 150$ I think from the kubota dealer.
This is after I went thru the rest of the things that could cause problems.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-15-2017, 04:22 PM
Jibber's Avatar
Jibber Jibber is offline
I would go ahead and replace the governor spring as well. My 2182 ran alot smoother and idled better after replacing the spring. These springs get worn out over time and it is not always visible when looking at the spring.
http://www.ebay.com/itm/GENUINE-KUBO...-/222187715433
