Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 06-02-2017, 05:00 PM
Default Engine question 14hp briggs
Is the lifter / cam follower crushable ?
Like made out of soft metal on B &S mod#
287-707 vert shaft
I have a old 14 -42 rider it quit years ago no compression ,Pulling the valve cover I have good compression but the exhaust valve adjust will mot take up the play , any one had this ? Push rod is ok ,valves work ok
I am thinking of putting this motor out front of mt 128 to make 4wd ....see now its a cub cadet ?
Old 06-03-2017, 12:03 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
how do you know the valves work ? valve seat fall out? some Briggs engines have plastic lobes on the cam.
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 06-03-2017, 01:11 PM
It does have good compression ,seals up nicely
Maybe a slow valve at first from years of sitting
Rockers are good , possibly I switched the pushrods back then and they are different, but yeah, if a seat moved that would do it
