Jeff, do you care to say what you are using for material? Reason I ask is that I have often thought what spindles are made of. I mean Haban spindles are getting close to spindles on grooming mowers.
We have an really old Lilliston 7'6" 3pt mower with big beefy spindles. Quite a bit of welding for the blade mount. Just wondering if its a tool steel that has to be drawn back/annealed after welding and how much machining takes place after welding. You'll have to forgive my ramblings, been on a run of parts that had to be straightened at 30 tons after welding so we could finish machine them--Got them within .010" out of the press.
It's 1060 but any welding that I do will be in areas where the hardened material is cut away.
I will be using TIG with 80 series filler wire. |
Thank you for taking pride in what you do!!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
So, is that similar to Thompson rod?
Looks awesome Jeff! They only advice that I can give here is that the post should read "Haban 325 and 374"....not 375. I know, I'm being a smart azz.
Those are still available from Cub
http://www.cubcadet.com/equipment/AR...0-A/0062100003 $132.97 from these guys https://www.cubcadetpartsnmore.com/m...t-spindle.html
( pointing up ) I will beat that price with the expensive spindles. I want to talk with the welding engineer at work before welding to make sure I don't waste very expensive material.
~~~~~~~~~~~~~~~~~ I got some material at work today, 1-1/2" diameter 4130 alloy steel. This is what I'll make the first couple sets out of. |
One done
As always Jeff, thank you for taking the time and making top notch replacement parts for us.
Thread Tools | |
Display Modes | |
