Greg Rozar AKA- CubDieselFan
Old 12-26-2017, 10:01 AM
Daniel_110 Daniel_110 is offline
Default Plow attachment
So a friend of mine got a 102, with a snow blower and a snow plow blade,( I dont know if either were ever on this tractor) he called me and said he couldn't figure out how the blade mounted on the tractor, I said it should be pretty self explanatory but low and behold, its not.So first off his tractor does not have the quick connect set up like all my cubs do, this I didn't know, I had him bring the plow and bracket to my house to figure it out but when we tried to mount to my 104, it was 3/4" too narrow to fit the front end and the brackets didn't seem long enough to not interfere with the axle and steering linkage, Im thinking were missing a few brackets or something, or hes got the wrong assembly all together Can someone send me a photo of a plow assembly that would fit this tractor
Old 12-26-2017, 10:04 AM
There should be a bracket with three holes in it for each side, the end with two holes bolts to the outside of the plow frame and the other end bolts to the tractor.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-26-2017, 10:31 AM
How about you post a picture of what you have, and we can tell you if it's right, wrong, or been modified. That makes more sense to me.
Old 12-26-2017, 11:33 AM
There are different subframe configurations even within the narrow frame series. I had the same issues and ended up cutting off vertical arms and moved them from the inside and moved to the outside and rewelded. I think my subframe was originally for a 70/100 and I installed on my 73 after modifying. Tim is correct for additional bolt on extensions as well. Info is in the tech section look at page 10, bolt on vs qa
http://www.onlycubcadets.net/pdf/CPE-2A%20Blades.pdf
Old 12-26-2017, 02:24 PM
Yes i figured we were missing some parts, we dont have the bolt on brackets, unfortunately I dont have a photo or i would post, thank you all
Old 12-28-2017, 09:15 PM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
These may be what you are looking for, depending on what plow subframe you have. They bolt onto the top of the tabs on the subframe.
https://www.ebay.com/itm/172437674239
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
Old 12-29-2017, 06:36 AM
how about you post a picture of what you have, and we can tell you if it's right, wrong, or been modified.
x2.....
Roland Bedell
Buy: Made in the USA
Thread Tools
Display Modes
