Greg Rozar AKA- CubDieselFan
Old 09-13-2017, 07:59 PM
It is much easier to split the tractor to gain access to the rear coupler, It would be a good time to clean and do some maintenance to the hydro unit whilest you have it out.
This is a solid piece of advice.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-14-2017, 06:31 AM
charlie105's Avatar
charlie105 charlie105 is offline
Noooooo--I dont want to !! I split it 3 yrs. ago for the trunion repair, speed cam, bushings, transaxle cover gasket, de-gunking, and that famous hydro gasket. Please tell me there is a tool for installing/removing pins.
Old 09-14-2017, 07:46 AM
ironman's Avatar
ironman ironman is offline
I own a 105 and I just took a look under there. Personally I don't see how you could get any kind of tool in there, room wise. Then again, once you get the pin out your still going to have to unbolt the motor and all the crap on it to move it forward enough to change your flex discs. Seems like six of one and half dozen of the other. I am in the same boat as mine has a broken fan blade I'd like to change.
Old 09-14-2017, 09:22 AM
charlie105's Avatar
Default Weld drive hub
The motor is out. I removed the; coil pin(it had almost fallen out), rear coupler, rag joint, fan, and drive shaft with the transaxle in place. It took some work, but I am confident it can all go back together without pulling the transaxle out of the frame. There must be a tool for installing the coil pin. Please let there be a tool
Old 09-14-2017, 10:04 AM
Yes there is a tool, it is called a roll pin punche, they have a flat end with a little teat on the end.
Mine are painted red so the blood, from hitting your knuckles matches.
I extent the punch with a 3/8 socket on an extension, makes it less frustrating.
To start the pin I use the hex end of an old ratchet extension to start it.
Then I finish it off with the punch.
You have the motor out so you can stand it vertical on the rear tires for even better access.
Up to 530 and counting...
Old 09-14-2017, 12:56 PM
charlie105's Avatar
Default Drive hub
Yes I have roll pin punches, but standing it on end still wouldn't give me any way to back up the shaft and protect the shaft bearings if I use a hammer & punch to drive the pin. I need a press or clamp to drive the pin without impacting the hydro shaft bearings.Trying to figure out how to modify a C clamp to do the job.
Old 09-14-2017, 01:19 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Or just pull the rear end out.
It could have been out already!
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 09-14-2017, 11:57 PM
Old 09-15-2017, 08:09 AM
Another tip that will help get the pin started is to taper the end with a grinder.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-15-2017, 08:10 AM
sawdustdad's Avatar
Rather than welding the drive hub, you could go back with a rag joint at the motor? I did this on my 149.
