CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 03-07-2017, 01:50 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Might be ok for a few tools and tires but you won't be happy with it in the long run.You need 5hp or bigger.The old saying you get what you pay for.
Old 03-08-2017, 01:04 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by ambrola View Post
This just popped up on CL. Would this be ok?
https://hickory.craigslist.org/tls/6016672443.html
Like Mike said... a bit small in the long run... Would do well with light use but not enough for blast cabinet or HD sanding... just my thoughts
Jay
Proud owner of the following:
Old 03-08-2017, 07:37 AM
ambrola's Avatar
ambrola ambrola is offline
Looks like I need to just bite the bullet and buy the Quincy I was looking at.
Old 03-19-2017, 09:52 AM
ambrola's Avatar
I'm with Brianna Beth on this one Ronnie. Although we could advise you, it's much better to consult and electrician.
Update on the compressor. I bought the Quincy after talking with my electrician buddy. At 18 CFM, I should have all the air I'll ever need. He only had to put another 220 line in the box and I am ready to go.
http://www.northerntool.com/shop/too...dkTRoC_CTw_wcB
Old 03-19-2017, 10:09 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Awesome! You will have more than enough cfm for your projects.
Queen Of The Quietlines!
Old 03-19-2017, 11:26 AM
Terry C's Avatar
Terry C Terry C is offline
Congrats on the new compressor. I know it is not the most fun tool to buy, but it will make using the air tools more enjoyable.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-24-2017, 02:11 PM
ambrola's Avatar
Update time. Finally got the thing wired and plumed. I have a couple drops around the garage now so I don't have to rely on just getting air at the compressor. But now I have another question, what should I use as a inline water filter? I have looked at them, but I wouldn't know a good one from a bad one? Also a regulator at the compressor?
Old 04-24-2017, 05:22 PM
john hall's Avatar
We don't have a water separator on the one in the farm shop, no real need since I don't use it for sandblasting or painting. I do need to drain the tank though. On our old ones at work we plumbed 1/4" copper tubing to a valve we could easily get to so we could keep the tanks drained easily--those crappy valves on the tank are destined to break quickly. We eventually got big enough to get an air drier and rotary compressor.
I don't use a regulator here unless I am in the old shop painting. At work we have the regulator right where the air comes in the shop so we can monitor it if a problem arises without having to go outside to the compressor house. Nothing fancy, just pretty good size--we have about 15 guys on the shop floor. You should be able to get a regulator/water separator combination unit.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-05-2017, 01:38 PM
dodge trucker dodge trucker is offline
I have a 5hp 80 gallon upright made by Emglo. 1987 model. I bought it out of the local classifieds, remember those? 2 stage 4 cylinder pump, 220 single phase. Rated for something like 19 CFM at 175 psi. I did rebuild it a year and a half ago, had a bad valve in one of the heads. Did new rings gaskets and all of the valves. Not quite the same as when I 1st got it but way better than running it when it had the stuck valve.... Still puts out the volume ok, but it seems like recovery was a little faster before the valve issue I had.... Tons better than while that issue was happening. Best$500 I ever spent, rebuild many years later cost me about 1/3 of what I bought it for.
As a backup I have a single stage Emglo with a 5hp Briggs for power.
Old 05-05-2017, 01:54 PM
DeltaCub's Avatar
You should plenty of CFM's with that monster. However, a 5 hp motor, single phase....Yikes! Your electric bill must be astronomical.
Thread Tools
Display Modes
