CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 09-29-2016, 12:10 PM
mattfrill mattfrill is offline
Default Enforcer only cuts shorter grass
Hello Everyone.
I am new to this site and I may be posting this in the wrong spot,feel free to advise me.
I have a older but well maintained Cub Cadet Enforcer,2008 I think.The engine is in perfect running order,compression is at factory level,High running RPM,s may be a tad bit low but now by much.Belsts are new,unit very well greased,blades keep sharp.
Here is my problem. I cannot cut longer grass with this unit unless I crawl with it,I have a cub cadet rider,21 hp I think,it will fly past it.When in long grass the RPM on unit drops and grass is not cut very even then.Keep in mind I have ear protection on and I am not 100 percent sure rpms are dropping a large amount.Blades are on tight and do not slip. I was wondering if it may be my electronic blade clutch,do they slip with age? Thanks for any advise or direction I should go. Matt
Old 09-29-2016, 01:05 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Sounds like blade is on wrong.
Old 09-29-2016, 02:09 PM
all blades are properly installed for uplift of grass,could be sharper but are not that bad.I did look for that mind you but all is good.
Old 09-29-2016, 02:35 PM
Sam Mac Sam Mac is online now
Any chance you have oil leaking onto the PTO?
Old 09-29-2016, 02:38 PM
Check out these guys for PTO info or if you do need to replace it. They have some very good videos on trouble shooting problems.
http://www.onlycubcadets.net/forum/s...ad.php?t=45466
Old 09-29-2016, 03:50 PM
I will look for oil,never thought about that. I will also check the video ,may be something there for me.thanks
Old 09-29-2016, 07:48 PM
The belt on my cub cadet zero turn will sometime jump off the tensioner, but the blades still turn and does pretty much what you describe.
Might give it a look.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Thread Tools
Display Modes
